Hey all after upgrading from v-7 to v8 I'm having trouble adjusting the latency in the software any suggestions would be great thanks.
geposted Wed 15 Apr 15 @ 5:57 pm
a little more info ...
useing a controller w/ asio driver
internal sound card ????
what ya got?
also if u just cant find it check advanced options top right of window and go to the performance settings.
what ya got?
geposted Wed 15 Apr 15 @ 6:32 pm
I dj 3 it worked great with vertual 7
geposted Thu 16 Apr 15 @ 7:36 am
since your not giving us much to work with i suggest you have a look at this web page and follow the advice on the link that deal with -> Common Computer Performance Issues
there a link for pc and one for mac -> http://www.virtualdj.com/wiki/Controller%20Configuration%20And%20Troubleshooting.html
good luck
good luck
geposted Thu 16 Apr 15 @ 1:56 pm
