another little bug in VDJ 8. ok heres the thing, VDj8 was working fine yesterday and today there's no audio. my other VDJ7 works fine with no problems but VDj8 today is no audio but if i broadcast i can hear audio on my radio broadcast but not in my speakers.(and i used to get both audio in my speakers and radio broadcast)i have deleted VDj8 and did a re install and the same thing,no audio output to my speakers. i have checked my setting and nada. can someone help please
geposted Sat 18 Apr 15 @ 11:40 am
Screenshot of your Audio Config Tab might be helpful.
Where did you plugged in your Speakers ?
Controller ? Computer ?
geposted Sat 18 Apr 15 @ 1:44 pm
Exact same problem for me aswell. The only sound i get is when i trigger a sample. Also no LEDS on my controller
geposted Sat 18 Apr 15 @ 3:54 pm
Same Problem .... same Informations as above required ;-)
geposted Sat 18 Apr 15 @ 3:56 pm
Problem solved, I just restored factory settings in configuration.
geposted Sat 18 Apr 15 @ 4:02 pm
geposted Sat 18 Apr 15 @ 4:05 pm
Speaker only,Internal soundcard,no mic,line in or timecode , still no audio. my speakers are plugged to my speaker out in my souncard, like i said anything sounds besides VDJ 8, 7 works and sounds fine.
geposted Sat 18 Apr 15 @ 4:30 pm
which source/ soundcard and channel routing ?
geposted Sat 18 Apr 15 @ 4:59 pm
Actually show us a screen shot
geposted Sat 18 Apr 15 @ 5:06 pm
ok found out what was going on, i have a M-Audio torq mix lab and what happens is that when i have the mix lab hooked up to my pc the settings where muting my audio. unhooked my m-audio and now its working again,thanks for the help
geposted Tue 21 Apr 15 @ 11:43 pm
