Forum: Old versions
Topic: Vdj 8 + mac + pioneer ddj-sx
dsr215PRO InfinityMember since 2014
Hi,
I'm running:
Vdj 8. (V 8.0.0 mac build 2174.951
Macbook 2009 w/ osx 10.9.5. 2.13 ghz core 2 duo w/ 4 gb sdram & 1 tb @ 7200 rpm
Pioneer ddj-sx w/ latest firmware
My issue is that the response from my cues is really bad. I have the sensitivity set to max on the sx and the mac isnt running any other software. Its stricly used for djing. When i press one of the pads on the sx, there's a slight lag. We tried it with serato on a seperate mac and everything ran 100%. This happens even in internal mode. Is there any way to get better response fron the cues? I looked at the settings and searched the forums but i couldnt find anything.
Also, there is a pc optimizer but no mac version. Does anyone know of such a program to optimize the mac for vdj?
Thanks
geposted Mon 20 Apr 15 @ 7:55 am
Hm maybe you set "smartCueQuantize" to on?
geposted Mon 20 Apr 15 @ 8:36 am
Thanks. That did it. It was set to 1. Changed it to .25.
geposted Mon 20 Apr 15 @ 4:16 pm
