I seem to have a problem with my deck select thought the headphones. Im using usb card 1 for the master through the system and then usb 2 card for my headphones as I did in virtual DJ 7. In 7, when I selected a deck it would automatically come through my headphones on both sides. In 8, it seems different unless there is something im doing incorrect. when I select TAB or a deck onto the side I want to cue, its not acting as it did in 7, Is there something Im doing incorrect please. Thank u.
geposted Thu 23 Apr 15 @ 1:35 pm
Check advanced options, search PFL, is it set to Yes.
geposted Thu 23 Apr 15 @ 1:55 pm
Hello. Yes its set to yes.
geposted Thu 23 Apr 15 @ 1:57 pm
Ive noticed that when I select a deck the pfl on the mixer does not follow. This seems to be the problem. I thought the pfl and the A and B button should should move together ?
geposted Thu 23 Apr 15 @ 2:00 pm
Ok, ive also just noticed that for example if I select load a track to deck b, the pfl will follow but then when I select deck A, the pfl stays on B ? I have to manually press pfl to turn on or off
geposted Thu 23 Apr 15 @ 2:02 pm
Hey Man Ive sorted it. Im sorry silly me
geposted Thu 23 Apr 15 @ 2:20 pm
