Forum: Old versions
Topic: VDJ8 doesn't detect my NS7 II
DjRatRHome userMember since 2010
Just got the NS7//, and while I like Serato DJ's post fader effects, I'm not digging how basic and stripped down it is (you can't even remap the controller FFS). So I installed VDJ8, and while it recognizes the controller's sound card and plays audio through it just fine, nothing but the keyboard shows up when I go to the controller settings.
Am I missing something here? I already installed the drivers for the NS7// so why isn't it working? It works fine in Serato.
geposted Wed 29 Apr 15 @ 11:25 pm
Open Config and look at the top of the window. What is the exact number of VirtualDJ build (xxxx.xxx) ?
geposted Thu 30 Apr 15 @ 1:35 am
8.0.0 2206.972
Do I need to update?
geposted Thu 30 Apr 15 @ 1:54 pm
Even if this post is in the PC Forum, i still have to ask you, you are on Windows, right ?
Anyways, things that you can try...
- Completely uninstall VirtualDJ and clean registries as well. Try to re-install VirtualDJ (after rebooting) from the official link here.. http://www.virtualdj.com/download/index.html
- Try a different USB cable and/or port
- Check Device Manager to see if the unit is properly detected and no "Yellow icons" exist there for the unit.
- Clean USBHistory using Oblivion (Google it)
- See if Miditrace or MIDIOX (Google it) see the unit properly
If none of the above help, please post here the content of the Log Report.txt you will find in /Documents/VirtualDJ folder.
To get this file..
- Open VirtualDJ 8, goto Config-/OPTIONS tab and change the CreateMIDILog setting (in Advanced Settings) to Yes.
- Close VirtualDJ, connect the NS7II (if not connected already) and relaunch.
- Close VirtualDJ again and the file should be available now.
geposted Thu 30 Apr 15 @ 5:07 pm
Windows 8.1 Pro x64
Quote :
I rather not since I have VDJ 7.4 installed as well and don't want to risk losing my settings, mappings, and database in that version by screwing with the registry.
Quote :
Didn't work
Quote :
No problems. The NS7// shows up under Audio inputs and outputs; Sound, video, and game controllers; and Universal Serial Bus controllers with no errors.
Quote :
After researching what it does, I rather not.
Quote :
Shows up in MIDIOX and all functions are detected. This was to be expected since the controller already works fine in Serato DJ and FL Studio.
Quote :
To get this file..
Here's the log:
--- 2015/05/02 - 11:50
Audio device found: name="Realtek High Definition Audio" vid="0x10EC" pid="0x0892" hardwareID:"{0.0.0.00000000}.{0b5a835b-0688-49d3-98c7-1dcebd249de1}"
Audio device found: name="Numark NS7 II Audio - WDM 2.9.64" vid="0x15E4" pid="0x002C" mid="0xFFFFFFFF" hardwareID:"{0.0.0.00000000}.{a470e75a-2388-4015-9aaf-98729eac091d}"
Audio device found: input name="Microphone (Realtek High Definition Audio)" vid="0x10EC" pid="0x0892" hardwareID:"{0.0.1.00000000}.{98ba3c1b-ac96-406e-b91a-5aa27b3e895f}"
Audio device found: input name="Stereo Mix (Realtek High Definition Audio)" vid="0x10EC" pid="0x0892" hardwareID:"{0.0.1.00000000}.{e5f17441-a480-4a75-8f1f-a2c89b51f4bd}"
Audio device found: input name="Numark NS7 II Audio - WDM 2.9.64" vid="0x15E4" pid="0x002C" mid="0xFFFFFFFF" hardwareID:"{0.0.1.00000000}.{efd49e50-37b8-45b4-9932-240fb484c21b}"
Audio device found: asio="ASIO4ALL v2" vid="0x1AA1" pid="0x0120" hardwareID:"232685C6-6548-49D8-846D4141A3EF7560"
Audio device found: asio="NS7 II USB Audio Device" vid="0x15E4" pid="0x002C" hardwareID:"2240292B-D6A2-470E-A0C1F9A14F837B41"
Audio device found: asio="Stanton 1394 ASIO Driver" vid="0x0105" pid="0x0001" hardwareID:"590EDB87-524A-453E-8456E8954C4B019F"
Midi out device detected, name:Microsoft GS Wavetable Synth mid:1 pid:27
MIDI Device Identifying: \\?\usb#vid_15e4&pid_002c&mi_00#6&1135db03&0&id01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\numark_ns7ii_midi01 (in:0 out:1)
MIDI Device Identified by PID/VID: \\?\usb#vid_15e4&pid_002c&mi_00#6&1135db03&0&id01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\numark_ns7ii_midi01
[11:50] Midi In Closed (\\?\usb#vid_15e4&pid_002c&mi_00#6&1135db03&0&id01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\numark_ns7ii_midi01)
[11:16] Midi Out Closed (\\?\usb#vid_15e4&pid_002c&mi_00#6&1135db03&0&id01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\numark_ns7ii_midi01)
MIDI Device Identifying: Microsoft GS Wavetable Synth (in:-1 out:0)
[11:16] Midi Out Closed (Microsoft GS Wavetable Synth)
MIDI Device Not Identified: Microsoft GS Wavetable Synth
geposted Sat 02 May 15 @ 1:51 pm
For some unknown reason, your unofficial copy of VirtualDJ is creating issues. If you need to test your NS7II and proceed with a purchase of a VirtualDJ license, i would strongly suggest to backup your valuable mapping and database files (the VirtualDJ folder), clean the registries and the USB History and try VirtualDJ 8 from here... http://www.virtualdj.com/download/index.html
geposted Sun 03 May 15 @ 1:13 pm
I was thinking that might be the case. I wanted to make sure my controller worked before buying Pro.
EDIT: Could having VDJ7 installed alongside VDJ8 be causing problems as well?
geposted Mon 04 May 15 @ 11:49 am
Well after clearing USBHistory, backing up and deleting the Virtual DJ folder, and updating to 2245.978 the controller works. It still doens't work in 7.4, but so long as 8 works I'm happy.
geposted Fri 08 May 15 @ 3:27 pm
