Hi guys im playing with the POI editor (very cool!) and i put in a saved loop. is there any way i can get it so that when i hit the cue button it will play the loop on the closest downbeat. (so it stays in time) at the moment it kicks in bang on when i press it (my timings aint that good :) )
Cheers for the help
Matt
Cheers for the help
Matt
geposted Fri 01 May 15 @ 5:00 pm
You want smart cue. And for loose timing folk you want to set quantize to either 1 (this gives you 1/2 beat early or late) or 2 (1 beat early or late)
geposted Fri 01 May 15 @ 5:13 pm
tried that. it works with cues but not with the loops from the poi editor? (only one deck playing?)
geposted Fri 01 May 15 @ 5:33 pm
Surprising, in all honesty it is something you should practice, set up two loops (long ish +16) on a track and jump between the two every 8 beats, word of advice don't use your eyes use your ears.
but as a cheat until you get your timing down, set your loop as a action poi, they quantize.
geposted Fri 01 May 15 @ 5:59 pm
