i have tried creating a new filter using bpmdiff<=4 & bpmdiff>=4 tho i'm not sure if i'm doing it right as i'm not getting compatible songs or anything for that matter, could you please give a step by step run down on this? thanks... DOZA
geposted Sat 02 May 15 @ 11:40 pm
Just try
Bpm Difference < 5
that looks like what you are after.
Bpm Difference < 5
geposted Sun 03 May 15 @ 12:22 am
Step by step instructions please
geposted Sun 03 May 15 @ 12:56 am
What are you using V7 or 8?
Your top 2 commands conflict, like saying I only want to see things <1$ and I only want to see things> $1, so you see nothing like you requested
geposted Sun 03 May 15 @ 1:15 am
This is fun what's next
geposted Sun 03 May 15 @ 1:17 am
I changed it mate :-), (felt like taking the mickey but decided to be nice.
geposted Sun 03 May 15 @ 1:19 am
VDJ 8.0
Sorry i'm amature so don't really know what i'm doing
geposted Sun 03 May 15 @ 1:20 am
i got those comands from another thread... "create compatible songs filter"
geposted Sun 03 May 15 @ 1:21 am
Ok V8 the best way to learn is see something working, study it and then mess around with it
(why I was excluded from medical school :-) )
So what you want is "my library"
https://virtualdj.com/forums/189385/VirtualDJ_Plugins/MY_LIBRARY.html?page=1
It's got loads of filter folders already set up so you can see exactly how they work, in all honesty I don't see why this plugin isn't part of the install
geposted Sun 03 May 15 @ 1:27 am
thanks locodog... i used 7 years ago, but have just started using 8, very different
geposted Sun 03 May 15 @ 1:29 am
WOW?! Way complicated! i just want to be able to hit "compatible songs" and get it... like in previous version
geposted Sun 03 May 15 @ 1:36 am
Complicated, all you do is install and it's done.
try this then
Bpm Difference <5
try this then
Bpm Difference <5
geposted Sun 03 May 15 @ 1:39 am
Your current licenses do not allow you to download Tools is what i get
geposted Sun 03 May 15 @ 1:42 am
How and where do i type this Bpm Difference <5 ... step by step please
geposted Sun 03 May 15 @ 1:43 am
maybe i'll just download VDJ 7 again, where this was free and easily accessible
geposted Sun 03 May 15 @ 1:51 am
geposted Sun 03 May 15 @ 2:05 am
Is there this version for VDJ7?
geposted Thu 07 May 15 @ 10:04 am
I don't think so, the problem is V7 doesn't handle nested Vfolders
Another good reason to upgrade.
geposted Thu 07 May 15 @ 11:39 am
locodog wrote :
...V7 doesn't handle nested Vfolders...
It does if you edit the database file by hand but you need to know what you're doing... ;)
geposted Mon 18 May 15 @ 9:13 pm
