I was wondering when recording in Virtual DJ 8 are there any recommendations for breaking up songs example song 1 song 2 song 3 how would I go about doing that thanks in advance
P.s. now I'm getting one track when I burn it to CD with 10 to 12 songs on it and that's not working Thanks
geposted Sun 03 May 15 @ 6:08 am
Option recordAutosplit
geposted Sun 03 May 15 @ 6:12 am
For info - apparently the auto splitting only works if you mix using the crossfader.
You could split your file up after recording using audio editing s/w i.e. Audacity.
You could also use s/w designed for audio CD burning to insert track markers - this wouldn't require splitting up the file, it just tells the CD player that a new track starts at a certain point. Good for continuous mixes.
geposted Sun 03 May 15 @ 7:17 am
