Hello!
Is it possible to disable microphone playback when microphone is ON?
I need dis, cause i run my microphone through USB-card, and then into my controller where my headphones are, and therefor I get double playback. I dont like that.
Best regards
Best regards
geposted Tue 12 May 15 @ 6:39 am
think simple ... use a Mic with a common jack so you can manage it via your controller
geposted Tue 12 May 15 @ 7:06 am
As it is for radio usage, I'd like to use my condensator microphone, and therefor need a pre-amp., and I got that in my USB soundcard.
I guess this feature, selecting whether you want mic playback or not would be simple for VirtualDJ to implement. It is already available to the booth as an option.
geposted Tue 12 May 15 @ 7:18 am
I guess you are aware of the on off button on the skin?
geposted Tue 12 May 15 @ 7:46 am
Yes - I am. I want it to SEND my microphone sound, but not play it back, so I can't hear it. :)
So I miss a cue/PFL button next to the on/off button.
geposted Tue 12 May 15 @ 8:13 am
Just a guess, but maybe turning down the mic_volume solves your problem?
But I don't know if it will affect both, input and output vol.
geposted Tue 12 May 15 @ 10:58 am
Already tried. It does, which also makes sense.
geposted Tue 12 May 15 @ 11:43 am
Are your headphones set to master or headphones in audio config?
The mic should always be audible on master pretty sure the mic isn't audible in my headphones/pfl while broadcasting.
My headphones are set to headphones in audio config.
geposted Tue 12 May 15 @ 11:51 am
It is set to headphones. (ASIO)
Master: DDJ-SX MASTER
Headphones DDJ-SX Headphones
Mic: Steinberg C1 (Mic)
Then im outputting from my Steinberg to my SX's mic input. That's why I get double feed (ofcourse).
Therefor my interest in disabling the mic PFL/cue in VirtualDJ, as im getting it in the controller, and to avoid latency when im speaking, which we all know drives you crazy.
geposted Tue 12 May 15 @ 11:57 am
I know that sometimes Windows will have the playback of the microphone on. This will cause you to hear the mic through your headphones if it is accidently set to the default sound card.
geposted Wed 13 May 15 @ 9:20 am
