Topic: track analysis bug
analysis of a track with length >1hr for database update on details etc made the app crashed many times
geposted Tue 12 May 15 @ 9:06 am
Can't reproduce. Tested with different mixes all over 1 hour.
The only think I noticed while trying to analyse a 2.5 hour mix is, that it always stops at ~ 15% of analysing process.
But VDJ does not crash for me.
geposted Tue 12 May 15 @ 10:55 am
I have VDJ8 installed on my iMac & Macbook pro. Recently i noticed that on the iMac when i run the BPM analyses feature on an album of say ten songs. VDJ8 analyses about four songs and then stalls. So i have to shut down VDJ8 re-open and the do it again and it does another couple of songs & stalls gain. So i have to keep shutting down and re-opening, it unless i drag the song into the decks and let them play until it pick up the BPM, Key, etc...
On the Macbook Pro i noticed that it analyses three songs at a time rather than the one song it analyses on the iMac.
I have uninstalled the software on the iMac and re-installed it and have the same problem. [All the machines are running on the latest update released yesterday]
Your assistance on the matter would be appreciated.
geposted Thu 10 Sep 15 @ 5:47 pm
