After much wailing and gnashing of teeth, I found two solutions I can recommend for creating song lists from your music/karaoke collection... In my case, it was ~88,000 MP3+g karaoke files.
I had several false starts, trying software that should have worked but didn't, along with many that were fake or malicious sites and tripped off my antivirus software.... I found MediaMonkey was the key (http://www.mediamonkey.com/). This is an awesome free product that will scan your folders and then allow you to export the new playlist to CSV, XML, even native Excel Spreadsheet. I found it did a very good job of parsing artist and title information... I did discover that it was not finding my Zip Karaoke files (which in my case is about 200GB). So that got me searching for a program that would bulk extract zip files. I tried 7Zip and got close, but it bombed on the volume of folders, I think. WinZip also bombed out. Then I used WinRAR (http://download.cnet.com/WinRAR-64-bit/3000-2250_4-10965579.html) and it worked like a charm and in a fraction on the time that the others took to unzip the files files... After Unzipping with WinRar, Media Monkey can see all my files and I am able to export that list directly to Excel where I can clean it up a bit.
These products have paid and free versions. I was able to do what I needed with the free versions but am so impressed I may buy their paid versions anyway. Hope this works for others who want song lists of their collections.
John M.
Denver, CO
John M.
Denver, CO
geposted Fri 15 May 15 @ 6:13 pm
If i were Atomix, I would have a sit down with Adventis, because the a support patnership together would be game changing...its actually begging for it.
geposted Sat 16 May 15 @ 5:01 pm
A web developer or someone good with HTML can put together a page that will pull right from the VDJ database. I had some proof of concept working before, but became to busy. I pulled out of some of the karaoke work, so I didn't have as much interest.
geposted Sat 16 May 15 @ 6:05 pm
If you create a playlist with your karaoke files, and save it, you can try to use my tool I wrote a while ago.
It is able to read the playlist/ history list and creates a CSV or XML file.
Note: The tool will only read all history files by default. But you can open a plalist through the menu too.
Just give it a try ;)
https://virtualdj.com/forums/198528/addons/History_Converter.html
geposted Mon 18 May 15 @ 3:46 am
