I'm playing with a Numark DJ2Go and impressed with its abilities (as an emergency controller!) but I'm having one problem.
The jogwheels do not seem sensitive enough when searching/scratching, that is, for a large movement on the jogwheel there is only a small movement on the track.....
I'm gonna kick myself probably, but how can I modify the jogwheel parameter in the midi wrapper to increase its action?
Cheers, Rob
Cheers, Rob
geposted Tue 19 May 15 @ 6:21 am
There are two ways:
One way is to change the global sensitivity for all jogs via settings (this means it will affect all controllers you use with the software)
The other is to use a param_multiply action on the mapper:
E.g: param_multiply 1.5 & jogwheel
geposted Tue 19 May 15 @ 6:27 am
Thanks PhantomDJ, works flawlessly. (Did'nt change the global setting tho!!)
geposted Tue 19 May 15 @ 6:47 am
