What might be an easy task for you...well. Two questions. Why can't I rename a favorite folder and how do I map one key to control both decks? For instance while doing a live remix I'd like both decks to start playing with one press..Thanks for any replies.
geposted Sun 24 May 15 @ 7:28 am
deck 1 play & deck 2 play.
Renaming Fav folders I can do that here, what is different about your set up.
geposted Sun 24 May 15 @ 7:53 am
Thanks for the reply. I did the deck 1 play and deck 2 play . It worked.
geposted Sun 24 May 15 @ 10:55 am
