Forum: VirtualDJ Skins
Topic: browser zoom help?
im use vdj 8 & trying to make browser zoom with vdj 7 skin. I get confused because the player still appears on the browser list...can someone help me? Thanks :)
this is the xml :
<pannel id="default_browser" group="filebrowser" visible="yes">
<browser>
<size width="1259" height="322"></size>
<pos x="10" y="437"></pos>
</browser>
</pannel>
<pannel id ="large_browser" group="filebrowser" visible="no">
<browser>
<size width="1259" height="656"></size>
<pos x="10" y="104"></pos>
</browser>
</pannel>
<button action="skin_pannel 'default_browser' on ? skin_pannel 'large_browser' on : skin_pannel 'large_browser' on ? skin_pannel 'default_browser' on">
<tooltip>Browser Size</tooltip>
<size width="10" height="10"/>
<pos x="237" y="8"/>
<over x="763" y="3596"/>
<down x="763" y="3596"/>
</button>
Did i miss something?
geposted Fri 29 May 15 @ 3:07 am
<button action="skin_pannel 'default_browser' on ? skin_pannel 'large_browser' on : skin_pannel 'default_browser' on">
</button>
Thank you djtouchdan...i copy your xml ,but the player still appears (its double the player & the browser)
i dont know how to put a picture in this message,so i can show you.
sorry for my english :)
Here is what you should do...
1. Nest the entire normal skin inside a <panel></panel> (probably you need to leave the top panel with the clock, cpu etc outside this panel) like this..
<panel name="default_browser" group="filebrowser" visible="yes">
decks..
mixer...
etc..
<browser>
</browser>
</panel>
Then right after the end of this panel, create the 2nd panel with the large browser like this..
<panel name ="large_browser" group="filebrowser" visible="no">
<browser>
</browser>
and anything else you need to have here.
</panel>
The button to switch panels can be easily assigned as ..
<button action="skin_panelgroup 'filebrowser' +1">
</button>
Thank you for your help djdad...still no luck for me, im use vdj7 default skin.
maybe i still confused because my english or just a beginner to understand how to modify the skin : D
