Hey everyone,
I want to use my NS6 or NS7 with DJ just as a stand alone player. Even though I set the option to ignore and disable midi definitions in the options section, I can still scroll through the songs using the knob and other buttons also work.
I tried this on MAC and PC using both , what am I missing?
I basically want it to work like nothing is connected to it.
Thanks.
Thanks.
geposted Sat 30 May 15 @ 5:06 pm
Can you use the ignore mapping?
geposted Sat 30 May 15 @ 5:20 pm
I tried it still does even though its on ignore. In vdj 7 I don't have this issue however I cannot see serato crates on Mac.
Something is up with 8.
geposted Sat 30 May 15 @ 5:24 pm
Until there's a fix (if one is needed) why not make a custom mapping and delete all entries (make a custom, open it in a text editor and delete all entries, save)
geposted Sat 30 May 15 @ 5:52 pm
Ill try that, thanks.
geposted Mon 01 Jun 15 @ 8:45 am
