I've been forced to go back to using virtualdj 7 because with the most recent update the lyrics are on chopped on both sides when viewing kararoke on external screen. I dj karaoke 4 days a week and this is really inconvienient....please help thanks
This is what it looks like
geposted Mon 01 Jun 15 @ 7:51 pm
You could always have just gone back to an older v8 build ;)
This issue will be fixed in the next v8 build.
geposted Mon 01 Jun 15 @ 8:00 pm
how do i go back?
geposted Tue 02 Jun 15 @ 12:12 am
Instructions on downloading older versions are available here:
https://virtualdj.com/forums/193007/Beta_Builds_Regression_Bugs/how_to_download_previous_builds.html
geposted Tue 02 Jun 15 @ 4:57 am
Thanks but when i downloaded the previous version and installed it I couldn't get any audio with the same settings I had before. The song would play but no sound or signal bars on virtualdj...weird. Any other solution?
geposted Tue 02 Jun 15 @ 8:03 am
I think I've had this before, I need my laptop out, but there are video settings like like crop, and zoom if I remember right.
Look in the VDJ options, and also windows graphics card options, along with the monitor settings.
Even just try a different monitor.
Given what I've said you could also check the position of the moon! lol
geposted Wed 03 Jun 15 @ 6:47 pm
OK i've got my laptop out.
Go to VDJ8 options. Tick show advanced options box. Go to video. Try altering the letterBoxing option. You have three choices bars, crop, and zoom.
I would have thought your sound problem was audio configuration.
geposted Wed 03 Jun 15 @ 6:57 pm
Posted in VirtualDJ 8 bug-report Forum on 31/05/2015 by Adion... "the problem has been found, should be fixed soon"
https://virtualdj.com/forums/200959/VirtualDJ_8_bug-report_Forum/Karaoke_Title_Screen_Graphics_Cropped.html
geposted Wed 03 Jun 15 @ 7:05 pm
The above is still a good plan. I'm intrigued, but not quite enough to simulate the problem.
I haven't seen this problem in the form of a bug.
geposted Wed 03 Jun 15 @ 7:15 pm
Thanks everyone for attempting to help. Hopefully it will get fixed on next build
geposted Thu 11 Jun 15 @ 3:02 am
