I use a hercules LE mixing console and i have a problem when scratching the songs. When i release the wheel after the scratch is complete, i have a slight delay and a split second gap in the mixing/scratching ending and the song resuming playing normaly, can someone please advise me as too what settings i need too change in the configuiration menu, much appreciate it if some one can help
Djnicky2012
Djnicky2012
geposted Tue 02 Jun 15 @ 7:43 am
If you disable the setting 'touchWheelBackSpin' then you will get no delay, but will no longer be able to perform backspins by letting go of the jog.
geposted Tue 02 Jun 15 @ 9:02 am
And this has supposedly gotten better?? This exactly what I'm talking about.
It's a give and take with VDJ, why can't this be fixed cause it's obvious that the current way does not work........
geposted Tue 02 Jun 15 @ 11:31 am
