I would imagine that this has probably been covered numerous times here, but I have not been able to find it if it has.
I have installed iTunes on my laptop that I am running vdj7. I have a folder showing "iTunes" on the left hand side of vdj7, but none of my purchased iTunes content is showing there. how do I get vdj7 to recognize my iTunes music, etc ?
thanks !
thanks !
geposted Mon 08 Jun 15 @ 12:55 pm
thanks !
thanks !
Do you have other music in your iTunes library? For example, I use iTunes to manage the location of all of my music and videos
Is the purchased music DRM? iTunes used to provide the music with DRM protection. They stopped a long time ago, but maybe you have tracks that still have the protection, VDJ cannot read DRM music.
I use iTunes to create my playlists as well. VDJ8 is able to view the iTunes library just fine for me.
Did you right click where it says iTunes and reload? It should reload at start time, but I just wanted to make sure.
Is your iTunes library in the default location? You may need advanced options checked but look in SETTINGS>OPTIONS>BROWSER>iTunesDatabaseFile, see if the filepath is pointing to the correct spot.
geposted Mon 08 Jun 15 @ 2:36 pm
Something to do with this perhaps?
https://virtualdj.com/forums/194796/MAC_Version_Technical_Support/iTunes_12__VDJ_7_4_PRO.html
geposted Mon 08 Jun 15 @ 4:04 pm
I think I may have figured out my issue, and it was something really simple. DUH ! LoL ! thanks for answering and trying to help !
geposted Mon 08 Jun 15 @ 5:23 pm
