Topic: Multiple Folder Search
Is there away to search multiple folders simultaneously in the search field? example 90's, Hip Hop, R&B Dance
geposted Wed 10 Jun 15 @ 12:23 am
When you do search VDJ does search your entire database.
Yes, if i only type in 90's hip hop all 90's hip hop will show same for any other genre and decade. But if I want multiple decades or generes it won't show everything, and I only have 150-250 songs per folder on that drive.
If you have your media tagged with the year and the genre, you can create a smart filter that will look for a certain genre and year range. Or a few genre's and year range. Or file paths that only look in certain file system folders with certain genres and certain years.
The filtering can get pretty extensive
Have you checked out DJ-in-Norway's "My Library" add on? It has a lot of filters you can learn from.
https://virtualdj.com/addons/16760/My_Library.html
