What is the hot key to make the browser full screen
geposted Sat 13 Jun 15 @ 9:07 am
There is a skin available with that function, that looks like the default skin. I believe that it's called browser.
geposted Sat 13 Jun 15 @ 9:14 am
Yes. I know there are skins with a buttin to do it. But I'm looking to create a hot hey
geposted Sat 13 Jun 15 @ 9:51 am
the skin must have it built in then you will need to know the variables in the skin that perform the action to make a hot key
1..... skin must have it in it not all do
geposted Sat 13 Jun 15 @ 10:06 am
As said, you have to use a skin with it in, after that use the key learn function to find the variable/panel.
geposted Sat 13 Jun 15 @ 10:10 am
im also having a diffract time locating the effects area.. on the vdj8 skin
geposted Sat 13 Jun 15 @ 1:34 pm
manual page 15 - 19
i suggest you read though the rest as well :-)
geposted Sat 13 Jun 15 @ 1:49 pm
thank you wicked , I'm doing it right now..
geposted Sat 13 Jun 15 @ 6:20 pm
