Hi can any one help me set up my audio setting for a mac with 2 cdj 20000nx and a djm2000 nx ( I'm getting the audio coming of one channel) can some walk me thought the audio set plz .
geposted Sat 20 Jun 15 @ 4:17 am
From OFF (CDJs)...
1. Plug both USB
2. Turn ON CDJs *Try to turn On the Left Deck first - it might avoid inverted decks* (You will see message "A NEW DEVICE DETECTED" - Use Soundcard? Click Ok)
3. Configure your Audio Settings (First CDJ2000 Deck 1 Channel 1&2 / 2nd CDJ2000 Deck 2 Channel 1&2)
4. Click Link on CDJs (You'll see Control Mode USB Midi - Push Rotary Button to Connect)
(If display doesn't show tracks, Turn the Rotary Knob)
5. Play and Enjoy!
i just happened to connect my lappy to these bad boys like its been explained and they worked straight away... now connecting the mixer i never tried but i have put up a post for that not long ago
1. Plug both USB
5. Play and Enjoy!
geposted Sun 21 Jun 15 @ 8:35 am
