Forum: Addons
Topic: Freestyler Command Converter
geposted Wed 24 Jun 15 @ 5:32 pm
I cant seem to get this to work. I click import and select the database, but nothing shows in the window. Any idea what I am doing wrong?
It is looking at the database because it says 0 songs geladen which I think means 0 songs loaded but I dont know why.
New version of Freestyler Command Converter is approved and in download area available.
Issue solved: Database entries with no tags e.g. Author, Titel etc. will prevent to load any entry into the converter tool.
Thomas
Hi Thomas
I've downloaded and tried the application by opening both my old and new database files:
Old file is in the root folder of the drive: F:\VirtualDJ Local Database v6.xml (database file used by VDJ7)
New file is in F:\VirtualDJ\database.xml (VDJ2020 database file)
If I "Import" the old DB file the status bar displays "21420 Songs geladen.", but no songs are displayed. If I uncheck "Ansicht" - "Nur Freestyler Songs" the songs are listed, but if I click on any of the songs in the list "Lange" displays the time, but it is incorrect e.g. 544m:00s and the "Titel" displays the full path to the song, which is also incorrect. All the other fields displays "n/a". So I think the program does not read in the data correctly.
If I "Import" the new DB file, it just displays "0 Songs geladen." in the status bar - nothing else.
Please advise
Thank you
Adriaan
Is this plugin still available? I can't find it in the addon section in my VirtualDJ Pro
