Topic: BPM
Hi im having trouble with my BPM.....everytime i put a song to play ,in my playlist it is the right BPM ....but when i put it to play its is not the right BPM .....dont understand why???
thanks
geposted Sat 27 Jun 15 @ 8:42 am
sounds like autoBPMMatch is set to "yes"
Please check in settings/ (advanced) options
Thanks very much ...actualy it was on smart.....so i put it on no....thanks again
both settings affect the bpms
so, autoBPMMatch AND smartPlay should be set to "NO"
Some (rare) songs are not easy to identify bpm for virtualdj, the reason is related to song quality, etc... sometimes you can see that the bpm is the double or the half from the one that virtualdj detected.
Also consider that for older songs like in the 60-70-80's the bpm is not constantly, so it's not easy to auto match by virtualdj.
