Hello, I'm looking for some help with coding a button for VDJ7.
When the volume is 100%, I want a button that when I tap it it stays on 100%, but then when the tap is released the volume is 0%. What would the code be?
geposted Mon 29 Jun 15 @ 7:13 am
master_volume 0% while_pressed
geposted Mon 29 Jun 15 @ 7:18 am
Thanks but that's not what I'm looking for.
geposted Mon 29 Jun 15 @ 11:30 am
volume 0% & volume 100% while_pressed
Maybe, my V7 script is a distant memory,
windows filter keys may mess it up, I've got a vague idea how to do it with down ? & several variables. If needs be.
geposted Mon 29 Jun 15 @ 12:46 pm
This reads to me as you want to stay at 0%? If so...
If the volume is 100%, then when you lift that key the volume will go to 0%:
up ? volume 100% ? volume 0%
If you want it so that it works if the volume isn't 100%, but 99% or whatever:
up ? volume 0%
You can of course make it deck specific by prefixing with deck:
up ? deck 1 volume 100% ? deck 1 volume 0%
Or make it work on the master volume:
up ? master_volume 100% ? master_volume 0%
If that's not what you are looking for then you'll need to be more specific.
geposted Mon 29 Jun 15 @ 5:13 pm
how many times iv seen this... lost count
geposted Mon 29 Jun 15 @ 10:00 pm
Thanks Locodog - works perfectly. I didn't need to test those out SBDJ, but cheers for the help.
geposted Thu 02 Jul 15 @ 4:11 pm
