Hi, some files format like jpg, zip and rar don't open in vdj8.
Already add this files format in the field off filesformat and keeo the message error when i tried to open them.
What can i do?
Regards
What can i do?
Regards
geposted Mon 29 Jun 15 @ 12:06 pm
Not sure about jpg.
But .zip and .rar files are compressed files that requires a seperate program to extract.
No basic files for a DJ Software ;-)
geposted Mon 29 Jun 15 @ 1:26 pm
thanks for the the reply, but vdj 7 read all this files...
geposted Mon 29 Jun 15 @ 4:09 pm
ZIP's can be opened by VDJ. They are used for karaoke files.
Are you using a PC or MAC. There are some odd zip formats running around that VDJ will not open. I believe windows explorer will not either. The solution is to unzip an zip again with a supported compression.
EDIT: The problem with the ZIP that I'm thinking of was that some programs did not write the Header properly in the file. Unzipping them and reappoint them with something like 7zip fixes the problem.
geposted Tue 30 Jun 15 @ 12:31 am
