I have just opened VDJ to work on a mix - and it asked for a usual Update of the software which I did.
Now, when trying to add a cue point to deck 2 using my keyboard i.e. Ctrl & 9 (for a 9th CP) it actually adds that CP to Deck 1 (Deck 2 is set as the Master and Selected as the current Deck)
If I remove the track from Deck 1 and try again to add a CP to Deck 2 (or 3 or 4 as I'm using a 4 deck skin) it won't add anything - it will only add CP's to Deck 1 when there is a track loaded on it.
If I click on one of the POI's numbers (1 to 6) on each Deck, these work fine, its only if I try to add any using the keyboard or indeed by trying to add them directly in the POI Editor
Anyone got any ideas what's happening here please?
Thanks
Thanks
geposted Tue 07 Jul 15 @ 12:27 pm
Just to update in case anyone else has had the same problem.
After doing the update on VDJ it had set my default keyboard mapping to "Factory Default Alternative" instead of just "Factory Default"
I've changed it back now and all is good again !!
geposted Tue 07 Jul 15 @ 4:04 pm
