I can''t get this to work. I assign a button to action "Playlist_Randomize) and it don't work.
geposted Thu 09 Jul 15 @ 3:31 pm
Does it work if you use the skin menu instead of the action?
geposted Fri 10 Jul 15 @ 3:55 am
yes it works using Mouse clicking the Option "Shuffle" or Shuffle once".
I want to assigned a button (remotely controlled) to Randomly LOAD one of the list from the Playlist/Automix Panel by using a script like
Playlist_Randomize & Playlist_Load_and_Remove
geposted Fri 10 Jul 15 @ 10:25 am
rapitman also asking same thing.
https://virtualdj.com/forums/202225/General_Discussion/assign_a_custom_button_to__shuffle_once_.html
geposted Fri 10 Jul 15 @ 10:31 am
playlist_randomize is the Shuffle option, not the Shuffle Once option which doesn't have a script command at present.
geposted Fri 10 Jul 15 @ 10:41 am
@ MagicDJ, sorry for hijacking your post, but mine got locked, and i would just like to point out the difference
@ SBDJ, thanks Scott, but with all due respect I already know that the "playlist_randomize" script works as far as the command "shuffle" from the AM drop down menu is concerned, and can be assigned to a shortcut or whatever.
But I was asking a different question that had nothing to do with this original post.
maybe you could move it to wishes and new features for me instead of locking it, or I'll post it there again instead, whichever is easier for you.
best regards
ray
best regards
ray
geposted Fri 10 Jul 15 @ 1:04 pm
I've moved your original thread to Wishes & New Features, and I apologise for mis-interpreting :)
geposted Fri 10 Jul 15 @ 1:44 pm
