I saw that I have the option to get either a license for my controller or an unlimited license. I just want to know if there were any limitations to getting a license for just the controller as opposed to going all out and dropping $300 on the unlimited license. If I get the license for just my controller will I have all the features of the unlimited version but just for my controller? Thanks!
geposted Fri 10 Jul 15 @ 10:13 am
On the following chart the Controller License is considered VDJPlus and Pro is of course Pro.
https://virtualdj.com/products/virtualdj/comparison.html
and some quotes from the pricing page:
"If you are using VirtualDJ professionally (as defined in the EULA: "if you earn money using VirtualDJ"), you need to purchase a PRO license."
"In addition to giving you access to all existing and future controllers, a Pro license is also required if you want to use custom-made controller definitions (to use controllers that are not yet natively supported in VirtualDJ), to use the podcast storage, and to remove or change the logo on the video output."
quoted from, https://virtualdj.com/products/virtualdj/price.html
My personal opinion, if you have the 300 bones, you are making a great investment buying a Pro Infinity license.
geposted Fri 10 Jul 15 @ 12:19 pm
What happens if you want to use different controller, or something happens to the controller you have? With the Pro, you can use any and all controllers.
geposted Fri 10 Jul 15 @ 6:55 pm
