Topic: Changing audio output device by script/button?
Hi VDJs!
I am using different audio interfaces with VDJ. E.g. at home when preparing a set I often use the build-in output. When teaching I am using an USB audio interface. Right now I am switching each time manually between the audio output options, which is ok, but not very convenient. So I wonder if I could assing a controller button / keyboard shortcut to switch to a certain audio output device in VDJ.
I looked through the list of verbs but I couldnt find anything concerning the audio output.
Any ideas?
geposted Sat 11 Jul 15 @ 3:27 pm
Hm. Another way of solving that would maybe be to create a "aggregate audio device" in MacOs Audio and Midi Setup. Has anybody experience if this works reliably with VDJ?
Ok, just tested using an aggregated device, the result is crackling sounds in at least one of the output devices. Thats a pity.
So still I would appreciate any advice how to simplify the switching between audio outputs.
You could save different Audio configs like that:
The just select the one you need and press apply.
Right, but still this requires several mouse clicks, multiple times a day, always...
