Is it possible to used 2 or more controllers simultaneously on VIRTUAL DJ???
I am using DDJ ERGO and plan to add pad controllers..is it going to work???
geposted Wed 15 Jul 15 @ 11:39 am
Absolutely.
My main setup is a MIDI enabled mixer with a pair of 1210s with a pair of Reloop Neons. Another one of my setups is a MIDI enabled mixer, 2 CDJ-2000 Nexus and the same pair of Neons.
No trouble at all :)
geposted Wed 15 Jul 15 @ 12:17 pm
I currently use a 14mxr mixer and a ddj sp1 with no issues whatsoever.
geposted Thu 16 Jul 15 @ 6:25 am
I sometimes add a Novation Launchpad to my regular controller setup to trigger things.
No issues on v7 or v8
geposted Thu 16 Jul 15 @ 10:22 am
You can add and use as many controllers as you want. Just make sure those are assigned to the correct/desired decks from the Controllers tab (Deck assignment)
geposted Thu 16 Jul 15 @ 10:35 am
This could be quite awesome for a B2B setup :)
geposted Sun 26 Jul 15 @ 3:11 am
I currently use the MC6000 (midi) together with AKAI APC mini and one NI Traktor Kontrol X1, with the intention to add a F1 aswell.
No probs!
No probs!
geposted Sun 26 Jul 15 @ 5:49 am
