lads i once i logged in once with my controller i dont ever have to do it again,i dont use internet at my gis,
went into options and says no need to log in yet window comming up
geposted Sat 18 Jul 15 @ 2:09 pm
What is your question?
geposted Sun 19 Jul 15 @ 11:52 am
it seems a log in window pops up on his computer, in spite of the fact that you only need to log on once to use the software...
geposted Mon 20 Jul 15 @ 6:28 am
If the login window has appeared then it means the user has either logged out manually.
Or has logged in to more than 2 machines and as a result the oldest machine will log off when connected to the internet.
If the machine doesn't EVER connect to the internet then it must be the first option.
geposted Mon 20 Jul 15 @ 6:46 am
only ever put my gig machine on net for this log in stuff ect so dont want to try gig this sat with 8 and after 10 mins pop up happens.
do i take it in internet options i need to select remain logged in or where is it.
and yes i will be gaving my fault free rig with 7 ready beside me
geposted Tue 21 Jul 15 @ 3:30 pm
You will only ever get logged out if:
* You log out manually
* You delete your license.dat file
* You set 'stayLoggedIn' to no (the default is and always has been yes)
* You have an active internet connection and have logged into any version of VDJ on 2 other machines since
geposted Tue 21 Jul 15 @ 3:41 pm
