Topic: 4 deck layout video output mixing
Hi all.
A quick question:
Does anyone know if it is possible to mix between more than 2 video sources (and see the videos on screen from all the decks, according to the fader level)?
In the 4 deck layout of the default skin the video mixer (set to automatic) will only work for deck 1 and 2, not for 3 and 4...
Or did I miss something blatently obvious and should I crawl in a dark corner and die of shame?
geposted Fri 24 Jul 15 @ 12:07 pm
pretty sure vdj only allows 2 decks with video mixing
Any Dev that can confirm this?
VDJ allows video mixing of any number of decks. The problem is that most transitions are only geared for the use of 2 decks. I did however create this:
https://virtualdj.com/plugins/?addonid=80282
It allows the use of all available decks and uses the level faders to mix the video rather than the crossfader. 4 decks, 6 decks, 99 decks, no problem :)
That's GREAT Scott!
I wonder, why haven't all transitions been "updated" like this?
Is there no demand for this? Am I the only deejay that wants to be able to mix three (or four) songs at the same time?
Because you have to consider the logic of existing transitions. Take a simple wipe - it only really works as a concept between two videos.
A transition really needs to be designed for the purpose.
I'm sure there will be more in the future.
You're right. I hadn't thought of that. LOL!
Thank you ever so much for this contribution. You made me very happy!
