Topic: What is this?
I noticed a new plugin called "Lottery". What is it and how do you use it? I have no idea where it came from, unless it was in an update.
geposted Sun 26 Jul 15 @ 2:18 am
Native Visual Effect in the last update if not mistaken.
Open the GUI of the FX. Select a Folder with pics.
Adjust how fast the pics will scroll.
Adjust how much time it will take for the last pic to stop.
Press Start button and the lottery begins.
Press Start button again, and you have the winner !
Thanks. At first I thought it was a virus (I know they are watching me), but then saw the gui. Could not remember adding it, so thought I'd ask. Works just as you described. The stop time determines how long it takes to stop, after you press stop. Nice new feature.
can you map the start/stop to a button ? (I been trying and can't figure it out).
deck master effect_button 'Lottery' 1 (if the effect is not selected)
deck master effect_button 1 (if selected already)
Thanks Dad for the Tip.
Modified it to my liking.
deck 1 effect_select 'Lottery' ? deck 1 effect_button 1 : deck 1 effect_select 'Lottery' & effect_active
I'm really like this Scripting thing
fine tune it a little bit
deck 1 effect_select 'Lottery' ? deck 1 effect_active ? deck 1 effect_button 1 :deck 1 effect_active : deck 1 effect_select 'Lottery' & effect_active
