Topic: Mapping effects on WEEGO
Hi all!
I would like to map my weego to regulate the effects from the Pitch. I almost achieved this by entering on the PITCH controller tab the command from the JOG_FX2 which is: effect 1 active ? effect 1 slider 1 : nothing
It worked pretty well but when I turned the pitch high the effect go down and when I turned the pitch low the effect go up.
How could I change this?
Thanks a lot!
Regards,
Juliàn
geposted Sun 26 Jul 15 @ 10:31 am
You can use "param_invert" to swap the way a control sends the midi message.
effect 1 active ? param_invert & effect 1 slider 1 : nothing
Thanks a lot!! It worked!! :))))))))))
