who knows, but the last several months i refuse to update my vdj.. No more suprises in a set for me.
geposted Fri 28 Jun 19 @ 3:35 pm
Read the wiki...
https://virtualdj.com/wiki/Sound%20Issues.html
geposted Fri 28 Jun 19 @ 4:35 pm
Same problem with my Denon MCX8000 After few hours (sometimes minutes...) The sound crackling...
I try Asio, wasapi, with Asio4All.
geposted Sun 30 Jun 19 @ 10:43 pm
Asio4all is not a real audio driver - it presents an ASIO driver to audio applications but uses the underlying audio driver. Latency is not improved and there is no good reason that I am aware of to use it with VDJ.
Have you tried WASAPI without ASIO4ALL? From your post I’d say no.
Also, have you tried other recommendations such as reading the post right above yours?
geposted Mon 01 Jul 19 @ 3:49 am
You can try uninstalling and re-installing the driver for that soundcard. Windows updates may have created changed to your audio setup. It once worked for me after struggling with this problem for months.
geposted Mon 01 Jul 19 @ 5:26 am
I have the same issue..I have an old mixtrac pro....works good no crackling/ popping...when I use my mixtrac pro mt3...then popping/crackling....very irritating!!
any suggestions on stopping this
geposted Sun 01 Mar 20 @ 8:45 pm
From four posts above yours...
groovindj wrote :
geposted Sun 01 Mar 20 @ 8:52 pm
