Been playing around with the sampler and scripts and I encountered what I think is a bug.
Let's take any Bank with 9 slots.
Slot/Pads 1,2,3,8,9 have Sample Stored but 4,5,6,7 are empty.
Assigned a button to activated either any of the pad 1 2 or 3 everything is good
Now assigned pad 8 and it will not play it because in the SAMPLER WINDOW (left browser window pane), what's stored on pad 8 is on slot/pad 4 (did not match) so it won't play.
Now if you change the pad 8 to 4, it will work, however on Right Window pane (sampler) it shows pad 8 is loaded (pad 4 is empty) and if you add/drag/drop a sample to #4, the #8 becomes #5.
The script that you made to activate a particular sample now is screwed up when using PAD #'s.
I hope I made sense.
geposted Tue 28 Jul 15 @ 9:46 am
I think this is what I am experiencing with the numark NV..there's supposed to be another thread with this topic.cant find it...
geposted Sun 13 Sep 15 @ 11:50 pm
