Topic: Mix Now Shortcut VDJ8 Automix
Is there a mix now shortcut like there was in VDJ7?
When doing wedding intros I like to have all the songs set up in a playlist that I can easily click MIXNOW to go from song to song as I'm introducing the couples.
I can't seem to find the ability to do this in VDJ8
geposted Fri 31 Jul 15 @ 1:33 am
map a button mix_now
Hi Nawtboy,
or you could use the AutomixSkip function and map that to a key/button, if you are using the latest build you can even change/detertime the length of the fade in the advanced options.
Just be aware that it's beats and not seconds like it used to be in Ver.7
