Topic: this is on my 3rd OS???
any ideas?
W10
asus gtx 560
17 2600 cpu @3.40
4gig ram
64 bit os
this is what it only shows
geposted Fri 31 Jul 15 @ 2:16 am
Check the Video driver - looks like you are using a MS generic one instead of the manufacturer one.
iv tried to update my drivers from GeForce.com and I keep getting this
maybe this is why my graphics card is spinning like it wants to take off...
I'm using the HDMI from the motherboard, that's why I cant work out how to fix this spinning situation maybe
haha, found the mini hdmi to hdmi connection, brb
my gig machine has the download but i havent installed it yet... i want to try W10 with vdj8 b4 i do my gig machine
i know the problem now with my Video Card... it needs TWO 6 pin power plugs and my power supply has ONE 6 pin plug... damn video card with two 6 pins
What the...?
How is it even possible to run without the second connector?
Anyway, I don't think that this causes the problem that only a part of VDJ is displayed.
iv disconected the gtx 560 now and i have full view of VDJ8
i did a you tube search on my vid card and it mentioned i need two 6 pin connectors
all i did was restart my computer then the full screen reset
Found these two connection on the bottom of all cables and connected my 2nd power cable to my vid card.
after an update driver for vid card, my card is working fine.
I have a full vission of V8.
And yes, its a two 6 point power system card
