In VideoAudioOnlyVisualisation is set to SLIDESHOW and when I activate the CAMERA now it does not work (v2352 & v2378). It used to work with no problem.
Is this the normal behavior now ? or should I try to find out what version it used to work on ?
geposted Mon 03 Aug 15 @ 12:53 pm
using the mouse to select/enable the camera plugin from MASTER, it does not work but a script that I made, makes it work. So all good to go.
geposted Mon 03 Aug 15 @ 8:36 pm
Just curious, but what script did you use then?
I don't think there should be a difference activating from a script or activating from the menu.
geposted Tue 04 Aug 15 @ 2:00 am
(Master Output) with a mouse, when you select the Camera plugin and enable it, it won't work probably because the slideshow is already running but works when you map a button/key to
video_fx_select "Slideshow" ? video_fx_select "Camera" & video_fx : Video_fx_select "Slideshow"
geposted Tue 04 Aug 15 @ 9:01 am
