Hello folks.
Is anybody using this controller with VDJ8 and if so how is it working. Is the mapping difficult or is it a plug and play?
geposted Thu 06 Aug 15 @ 7:46 am
Natively mapped.
geposted Thu 06 Aug 15 @ 7:48 am
As loco says it's natively mapped but pretty easy to custom map to your preferences. You can change the pad modes and the pad LED colours for example and it's not too difficult.
It works really well with VDJ8, I have had the SX2 since it came out and use it most weekends.
Keith
Keith
geposted Thu 06 Aug 15 @ 8:42 am
