I've been trying to figure out why the Karaoke SkipSilence not working. I have looked at everything and probably miss something obvious.
I have made sure this option in "YES" but it ignores it.
Is there anything else I need to look at ?
TIA
TIA
geposted Thu 06 Aug 15 @ 9:02 am
checked a few Karaoke tracks here, and the setting works fine (skips the silence)
Are you sure the track has a "silent" part" ? Can you post a screenshot of the rhythm-wave showing the load point ?
geposted Thu 06 Aug 15 @ 9:07 am
geposted Thu 06 Aug 15 @ 9:20 am
Weird. Any chance you have set any Load Points in POI Editor for those tracks ?
If you play the track from the beginning, do you hear anything ? I mean there could be some "noise" that VirtualDJ detects as sound.
geposted Thu 06 Aug 15 @ 9:27 am
I even edited it Audacity to make sure I clean up the beginning (CTRL-L) and created a new ZIP, still not skipping.
geposted Thu 06 Aug 15 @ 10:24 am
try this files.
one original and the other the one I cleaned up in Audacity.
http://1drv.ms/1HtpDLt
geposted Thu 06 Aug 15 @ 10:30 am
