Topic: no longer loading on first cue point?
in 8 my system was loading the songs and would set the start point at the first cue point I had set. I recently wiped my system and went to win10, so I reinstalled VDJ from scratch, now this is no longer happening. All my cue points are still there since I saved my database file but it is now setting everything to the start of the song vs the first cue.
Can't seem to find a setting that seems like it does this
geposted Thu 06 Aug 15 @ 6:55 pm
I don't have an option that says cue/skip silence, just each individually. The cue alone says it creates cue files for each song which I know I don't have from before, so I'm assuming the data was stored in the database itself
pioneer DDJ SX,SX2 DDJ SZ Itz Work on virtual Dj pro 7 ??............and Suggest Me which Controller Buy ?? Plz Help Me
just set the autocue option to cue, you should be good to go.
All my cue points from V.7 are gone in v.8.
I have too many songs to recue them all. Is there a way to bring all your cues over to V.8?
Can you use the Numark Mixtrack3 (controller) for VDJ which VDJ7 instead of VDJ8?
Yes sir, should be plug and play?
it does not plug and play. it only works with vdj8. I don't want to use 8. I want to use vdj7
can you help me?
Sorry, I was told it was plug and play with v7 as well as v8. I didn't see it on the list of compatible devices so I asked a reliable source. Maybe my question was misunderstood.
Let me dig around a lil.
Bad form KooBreeZ for hijacking the thread, the MT3 was released after V8 so you'll need a definition file and mapping file to work with v7
My apologies for hijacking the thread. I am new to this. It won't happen again. Thank you for answer.
