Windows 10.
There is a problem with install of Virtual DJ. Installer can't create folders for instalation. My Documents folder are in Google Drive folder, and i think that is the problem.
Any help?
Any help?
geposted Sun 09 Aug 15 @ 8:05 am
Solved...run as admin.
If you dont have option to run as admin...use this:
https://runasadminmsiexttink.codeplex.com/
geposted Sun 09 Aug 15 @ 8:15 am
