hi,
I was wondering if 100$ is too much for this used console on sale.
thanks for the info :)
geposted Fri 14 Aug 15 @ 2:33 pm
I try to get half price on second hand stuff.
Few things hold there price well once there used.
If I really wanted something I might go to 65% of the new price.
Is that the old RMX, and not the RMX mk2?
The RMX is old.
As with all Hercules stuff it is close to indestructible.
I assume that it is in good condition, and full working order.
The RMX is old.
geposted Fri 14 Aug 15 @ 3:06 pm
Bigron1
Its the one that costs 400$ new.
Btw, all those on sale (used) are most "hercules"...no good sign of quality ?
geposted Fri 14 Aug 15 @ 4:35 pm
Only you and the seller can decide the value of this controller. Just be advised that it will not come with the LE license, if the seller registered it. The license is non transferable.
geposted Fri 14 Aug 15 @ 4:40 pm
It comes with it (free) but dont know if it can be transfered..
ill have to buy one of my own ?
geposted Fri 14 Aug 15 @ 4:48 pm
geposted Fri 14 Aug 15 @ 5:53 pm
bigron1
Nope. Its the RMX.
http://medias.audiofanzine.com/images/normal/hercules-dj-console-rmx-24708.jpg
but its only 100$
Nope. Its the RMX.
but its only 100$
geposted Fri 14 Aug 15 @ 6:26 pm
I am telling you now, that the license cannot be transferred, if he has registered it in his name. Yes, you will have to buy your own license. Unless you know this person, I would not trust him if he says that the license is clean. That's just me, you may be the trusting type.
geposted Fri 14 Aug 15 @ 9:05 pm
I loved the rmx.. it was awesome.. the best part is the huge chunk of metal inside it.. with out it, its 10% of the weight. Keep it as a back up. It never failed me .. I bought it for 125 new. as Its a old controller.
geposted Sun 16 Aug 15 @ 2:14 am
