i notice a lag in the video playback, its as though the video is kind of slow motion, the music goes out of sync with the lips of the person.
i notice this does not happen with videos i download from DJ pools, but it normally happens with my own home made edits, and not all of the time
while i dont know what method of encoding the pools use, i try to match the resolution at least
i do .mp4 normally at 720 x 480 pixels with a h.264 codec and a bit depth of 3...
geposted Fri 21 Aug 15 @ 1:37 pm
if you put one of those pool files in this app -> http://www.headbands.com/gspot/v26x/index.htm
it will tell you all about the encoding and the codec used maybe it will help you match them up better
also i would use the same FPS as the pool files
geposted Sat 22 Aug 15 @ 12:01 am
