I need to add more rhythms, loops, samples, phrases to my sample library.
Advice where to find this and buy through download, is appreciated!
geposted Sun 23 Aug 15 @ 11:27 am
Just use Google and you'll find thousands. There are lots of free ones, and lots that cost money.
Loopmasters, Prime Loops, Future Loops, Producer Loops etc. etc.
geposted Sun 23 Aug 15 @ 12:32 pm
Vengeance sample packs
geposted Sun 23 Aug 15 @ 1:19 pm
Thanx, I appreciate your advice.
I know Google reveals a lot, but my question should actually be sites that you recommend!
I got a few now, thx
geposted Sun 23 Aug 15 @ 7:00 pm
http://movie-sounds.org/
I think I got some quite good Matrix, and Simpson clips here, however I struggling to find them now.
The movies, and TV has to be a major source.
It's worth a root around.
I'm fond of the Simpsons...."are we all mad yet?".
geposted Sun 23 Aug 15 @ 9:03 pm
The Casio SA-10 sound pack is free to download.
http://www.kvraudio.com/forum/viewtopic.php?t=250659
Again I can't remember where I got it from, but this might do, if not other links exist. It's like Project 8 on the VDJ addons website.
There may also be some useful stuff there from China!
I wouldn't recommend collecting too many samples, that may lead to confusion.
Learn to use, and know a manageable group seeking to be an expert in those sounds.
The SA-10 sound pack creates a virtual keyboard.
This kind of thing takes a lot of practice, and skill to integrate into your performance.
Don't forget to make samples from your own music.
For example "eat sleep rave repeat" overlayed on an instrumental section with a suitable key, and beat can be very good.
You can use a microphone to make your very own, this is my take the piss line "eat sleep work repeat".
I've never had the bottle to play it!
It's too close to the truth for comfort.
geposted Sun 23 Aug 15 @ 10:08 pm
