Hey all,
is it possible to set an action marker by using VDJScript?
Something like:
set marker 'marker1' 'set %test 1'
So that the 'marker1' marker would be set at the current playback position with the action of 'set %test 1'.
If not, how would I set a marker like that from my plugin?
Thanks in advance,
Marco
Something like:
Thanks in advance,
Marco
geposted Mon 24 Aug 15 @ 6:40 am
You can't write an action poi on the fly, but you can move an a action poi cue on the fly.
There's also the v7 plugin cue macro, that lets you pre write the action and link it to a cue name, then all you have do is place and name the cue which can be done on the fly.
geposted Mon 24 Aug 15 @ 8:02 am
So I can't even create the POIs through a plugin?
Does this mean that I would always have to create all POI cues by hand, for each individual track?
geposted Mon 24 Aug 15 @ 8:03 pm
Correct.
geposted Mon 24 Aug 15 @ 8:11 pm
Okay, but I can create normal cue points on the fly. Is it possible to name them through vdjscript?
geposted Mon 24 Aug 15 @ 8:42 pm
Yes, cue_name 1 'name'
geposted Mon 24 Aug 15 @ 8:55 pm
Ah nice, that will make for a good workaround then. Thank you both!
geposted Mon 24 Aug 15 @ 9:05 pm
