I've been in this forum since maybe a month a read a lot of threads concerning the software.
So i just want to be sure i understood well anything that has to do with vdj folders, VDJ data
HD reformat, PC swap.
the vdj folder has, the effects, the songs data, costum sampler, anything that has been "edited" in VDJ.
In case i move an amount of songs to a new folder, i will need to change the path info inside the data base file.
Custom sound settings are also located in a file inside the vdj folder in "my documents" folder.
Basically if i want to swap PC, or reinstall from hard disk backup, i'll need to back up the whole VDJ folder in "my documents"
and relocate it in the same "my documents" in the new PC, however, the VDJ folder inside "program files" does not need to be backedup.
Thanks for your advises :)
geposted Wed 26 Aug 15 @ 5:37 pm
I believe you can refer to these links https://virtualdj.com/wiki/Backup%20Database.html
https://virtualdj.com/wiki/PC%20Transfer%20To%20A%20New%20Computer.html
geposted Wed 26 Aug 15 @ 7:17 pm
