Hello,
I've just started Djing and I am currently Djing with a DJ WeGo3 and my iPad. I am wanting to get a laptop to use with my deck.
Can anyone suggest a decent cheap laptop?
Thanks
Thanks
geposted Tue 08 Sep 15 @ 7:57 pm
Simple answer .... pretty much any laptop will work with VDJ and your controller.
You will also need a VDJ licence as your controller will only work for 10 minutes on the home free version.
I would avoid the PC World £299 carp and go for something in the £399 to £450 range as it will be an infinitely better machine and a bit future proof. Also better to go for an Intel processor if possible.
geposted Tue 08 Sep 15 @ 8:17 pm
Asus seems to be the make our big guns get.
Kradcliffe is spot on.
Second hand from Ebay might be an option, but if your not technically up to fixing the thing, new is the way to go.
geposted Tue 08 Sep 15 @ 10:07 pm
