I need a laptop with decent video processing capabilities. Ideally it will have the ability to output to two external monitors along with the LCD, all of which must be at full HD (1080p).
I currently run a Lenovo X220 (only 2 ext monitors) and only 1366x768...time for an upgrade!
I also use additional software to overlay graphics, tickertapes, text messages etc and with the video output on only 2 monitors there is a little horizontal 'skipping' especially on fast moving/changing video.The smoothness of graphics is the most important issue, storage and ram are less of a problem. I will be using a 4tb ext hdd and probably 8gb ram on win7pro64. I will not consider a mac.
My budget is around $1500 (£1000UK) although I could stretch it a bit ;-)
Any suggestions? Thanks!
geposted Tue 08 Sep 15 @ 9:40 pm
Beatbreaker goes for Asus, and also searching for SBDJ's Asus laptop would be worthwhile. We were all impressed when he mentioned what he was using about a month ago. He is one of the main VDJ hardware ground breakers. He tries things before almost everybody. I suspect that is a big part of his job.
I think that Asus was about £1000.
Note: I'm thinking of a newish laptop to satisfy Traktors bloated requirements. My budget might be a little over £150.
I would spend more if I needed high performance video capabilities.
My middle name might be Frugal...but I make things work !
geposted Tue 08 Sep 15 @ 9:52 pm
SBDJ Laptop = ASUS G750
If I remember right the optical drive was removed, and a SSD hard drive inserted.
Presumably that is where his operating system is located.
Anyway wherever the SSD is located, then also is his operating system.
This looks good.
http://www.ebay.co.uk/itm/Asus-ROG-G750JM-i7-4710HQ-16Gb-1Tb-256Gb-SSD-17-3-FHD-nVidia-GTX-860M-2Gb-no-os-/351466604536?hash=item51d50ac7f8
I'd take out the optical drive replacing it with a conventional 1Tb HDD to use as a data partition for my songs, and stuff.
This looks good.
geposted Tue 08 Sep 15 @ 10:44 pm
geposted Wed 09 Sep 15 @ 2:56 am
Great suggestions, thanks for the input! I will investigate further. I have been looking at thinkpads T450s and W541s because they are bulletproof (and it's all I know) but Lenovo just ain't IBM. I can't justify the spec/price ratio any more..
geposted Wed 09 Sep 15 @ 7:21 am
Decided on the Asus G751 JL (ROG) with 12gb and Nvidia 965M... <£1000!! :-)
geposted Thu 10 Sep 15 @ 2:07 pm
